Painting engine bay - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2012, 04:04 PM
bigdog7373's Avatar
Of course it's fast
Painting engine bay
I need to paint the engine bay in my firebird. Only problem is i'm not pulling the engine. I am, however, getting a new intake and headers so i'll do it while thos eparts are out to give me some more room. Couple questions though:
1. What type of paint is best? I was thinking i need something that will hold up to high heat from the exhaust so maybe engine paint?
2. What kind of prep work is needed?
3. Best cleaner and degreaser? It's pretty nasty right now.
Old 08-01-2012, 03:12 PM
bigdog7373's Avatar
Of course it's fast
Bump.
Another question. Should i just do it all black or paint the inner fenders to match the body?
Old 08-01-2012, 06:44 PM
BarryK's Avatar
Cleaning, you could start with purple power or simple green to get it pretty clean, then you might mix a bucket of that cleaner with warm water and scrub with a red scuff pad, cleaning and sanding all in one.
You can use any paint in there as it does not need to be a high temp paint and the best and easiest would be black epoxy and leave it like that.
It is all about what you want but spraying color with engine in is no fun and a just about guaranteed screw up.
Nice thing about painting engine compartments, you can make it an 80 hour career or a two hour job, depending what you want the results to be,
Old 08-01-2012, 07:33 PM
Cape Cod Bob's Avatar
Use one of those high pressure washers. I think you can add some soap. Or get a can of scrubbing bubbles bath and tile cleaner and spray ob. Then hi pressure off.
Old 08-01-2012, 08:26 PM
Dennis W. Parks
The not so secret secret of good painting is to get the surface as clean as possible, as smooth as possible, and then not get any runs in the paint. I'm sure most folks will tell you to pull the engine if you are painting the engine compartment. You really should do that, but for reasons not disclosed here, you are not going to do that.
Try to use a high pressure washer with grease remover or any of the products alredy mentioned to get rid of as much grease as possible. Rinse well. Then use wax and grease remover to clean the surface again. Move as much stuff as you can away from the panels that you are going to paint. Scuff the surfaces with a red Scotch-Brite pad. To apply paint in the confined area, use a touchup (or jamb) gun. You may need to refill it several times, but it will minimize overspray. Since you will be painting sheet metal, you can use the same paint that is on the rest of the car. Match or compliment to suit your taste.
writerDennis
Old 08-01-2012, 08:52 PM
bigdog7373's Avatar
Of course it's fast
Thanks for the responces guys. I'll be sure to get it really clean.
I'm going to take as much off the engine as possibke them wrap the motor in plastic so i dont have to worry about getting paint on it.
The headers get pretty close in some places, isn't it going to melt the paint? I'd rather be safe and use high temp if it will help.
Painting engine bay GUITAR1989 Body - Exterior 4 06-15-2011 12:18 PM
Clean up engine bay bigdog7373 Hotrodding Basics 18 11-11-2010 11:44 PM
Increasing of engine bay Nightrider Body - Exterior 26 02-27-2007 06:07 PM
NewB Q about painting engine bay. BaNe Hotrodding Basics 3 02-16-2006 07:22 AM
engine bay 78 chevy truck Body - Exterior 24 11-19-2003 02:31 PM
