Painting an Engine Block!!!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2004, 07:22 AM
New Member
I have a 350 SB engine stripped down, just the bare block now and I used a drill with various steel brush attachments. Now the block is very clean and ready to be painted.
My question is: Do I need a primer first because it's right down to the metal? And can I use bc/bb paint on the block?
Old 12-13-2004, 07:24 AM
johnsongrass1's Avatar
Race it, Don't rice it!
yes
yes
make that 1st one a no
Old 12-13-2004, 07:27 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Paint it just like you would the car. Epoxy primer, BC/CC catalyzed urethane. Will withstand any chemical you throw at it (except stripper!) and all but the hottest parts of the engine. Exhaust X-over may degrades, although it hasn't gone bad on my Chrysler yet in 5 years. Powder coating is the Cadillac finish.
Old 12-13-2004, 07:30 AM
New Member
your saying I don't need a primer even if I use bc paint?
what about the heads, I know that they get hotter than the engine block?
Old 12-13-2004, 08:30 AM
batman09's Avatar
CLICK ON MY AVATAR
I would like to paint my heads too.Can someone walk me thru the procedure.(new dart heads).thanks bm
Old 12-13-2004, 08:37 AM
no rocket science here guys. Just use laquer thinner and wipe EVERY CROOK AND CRANNY down and make sure it is clean and oil free. Prime it. Then paint it! I use Plasticote paint out of a rattle can with good results. Its all in how clean you can get the cast iron.
The paint will look terrible on the rough casting if you don't prime!
Old 12-13-2004, 12:13 PM
New Member
Ktaves1971
Let me get this straight you first have to prime (what type of primer) before the paint(bc/cc)?
Because I talked to other friends and they said you do not have to prime. Thanks for taking the time to read this JM.
