Painting engine block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2006, 08:05 AM
62galaxiguy's Avatar
I have a qt of dupont chroma base & a qt of chroma clear.The machinist sprayed the engine with self etch primer to keep it from rusting.Can i use the dupont b/c system over this primer? THANKS MIKE
Old 09-15-2006, 08:17 PM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
I'd be surprised if it stood up to the heat. I'd go get some heat resistant paint, about every parts store carrys it.
Old 09-15-2006, 09:18 PM
Wiki Edits: 31
using BC/CC systems work very well on engine blocks, blocks don't get hot enough to scorch paint or cause it to flake. most times the blocks are not prepped right and causes the paint to flake from contaminates baking out from under it, so many people give it a bad rep ( even heat paint ). it won't stand the heat of headders or exhaust manifolds tho.
Old 09-15-2006, 09:54 PM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
I sprayed mine a couple of months ago with single stage (house brand from a local shop) and it has held up very well.
Old 09-16-2006, 05:42 PM
302 Z28's Avatar
BC/CC is one of the most durable paints there is for an engine block, far superior to what comes from ANY rattle can.
Vince
Old 09-17-2006, 01:40 PM
jimk's Avatar
I always use BC/CC and never had a problem.I prefer the omni clear,cheaper and I believes holds up much better.I don't use omni on the exterior of a car though.
chevy's engine block number HELP!!!!! gearaholic Engine 7 07-23-2007 10:13 PM
Ford Y Block Engine RetroJim Engine 11 06-14-2006 07:37 PM
Painting Engine Compartment parks911 Body - Exterior 2 02-13-2005 07:11 PM
painting engine and resale value mgof Engine 1 12-28-2003 09:09 PM
Painting an Engine Jackyl Engine 8 04-09-2003 05:14 PM
