painting engine parts, what to do? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2012, 03:29 PM
chevyhotrod's Avatar
I have a newly built 383 engine with afr aluminium heads and an aluminium intake.
I am going to paint the engine block and transmission in the same metallic as the truck. The engine will sometimes be visible from the outside without opening the hood.
What would you guys recommend, should i paint the heads and intake also?
or should i only paint the heads or only the intake.
I can not figure out what would look best. The truck and engine block will be in a dark brown metallic color.
Maybe some pictures would help.
It is going to be a street-rod style truck. Going for the classy look.
Old 02-21-2012, 11:56 AM
I would paint the block and tranny and let the heads and intake alone. Then you will have some shiny with your paint.
painting aluminum engine parts jss Body - Exterior 3 09-22-2011 11:10 PM
painting motorcycle parts drewmangoo Body - Exterior 6 08-22-2007 07:52 PM
Painting suspension parts Novanutcase Body - Exterior 4 05-16-2007 12:41 AM
painting three coat in parts? wothrottle Body - Exterior 3 11-19-2003 04:50 PM
Painting Engine Parts NavyJoe Engine 10 11-06-2003 05:03 PM
