Painting Engine question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2008, 01:44 PM
Will painting an engine contribute to overheating? I have a ford 4.6 alum.block and would like to paint it. I was told that I would be better off just cleaning it and hi-temp clear coat. Any thoughts out there?
Thanks in advance
Old 07-22-2008, 02:01 PM
Clear coat is just paint without pigment.Paint the color you want and don't worry about it.If painting it causes overheating you have far bigger problems to worry about.
Old 07-22-2008, 02:12 PM
dh79's Avatar
I agree 100%.
81 Grand Prix, 355, 700r4, 8.5" 4.10
64 Oldsmobile Jetstar, all original
Old 07-22-2008, 03:09 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Not likely..any overheating and you have other issues besides the paint..
Sam
Old 07-22-2008, 03:39 PM
theccrider's Avatar
always proceed, go forward
as the "myth" goes painting it a flat black will expel the heat more effectively than any other color, but wouldn't it absorb the heat from the headers too?
go ahead and paint it, no problems on this end
Old 07-22-2008, 03:47 PM
Actually that is no myth it is the result of a study on heat rejection by alcoa in the 60's.Flat black coatings reject or emit far more heat than a plain aluminum surface.
Old 07-22-2008, 05:45 PM
Thanks in advance
Bare aluminum is quite reactive to the elements, a good coat of paint protects it from water, air, battery acid, coolant spills, etc. that can cause pitting and corrosion of the material.
However, since aluminum forms an oxidation layer rapidly on exposure to air, getting paint to stick can be a problem. Often this is overcome by using a self etching primer.
If the engine is air cooled then a layer of paint can directly affect the operating temperature of the parts involved, but so does layers of corrosion and grime. If liquid cooled, there is plenty of extra cooling system capacity to handle any loss of heat rejection on the outside of the cooling jackets. So this is a non issue in the real world.
Bogie
Old 07-22-2008, 07:03 PM
Thanks everyone
Thanks for your help and suggestions. I will paint it.
Engine question!! stereodud Engine 27 10-01-2010 09:55 PM
engine question chevy 305 425HP Z28 Engine 6 11-10-2006 05:29 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
Hotrodders Guidelines -- READ ME Jon Suspension - Brakes - Steering 0 06-14-2003 06:03 PM
