painting fiber glass? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2006, 08:39 PM
I'm redoing a miniature corvett on . I've stripped all the paint off and done some repaires on the fiberglass and was planning on priming with crossfire 2k high build and painting with crossfire base and clear. I was just worried that the 2k primer would'nt be flexible enough and it might crack later down the road?
Old 10-11-2006, 08:57 PM
2k primer is fine for fiberglass, but as discsussed already, epoxy is best down first. There is a lot of information on fiberglass prep already if you do a search. I am confused what your are painting, miniature corvette what?? True corvettes have been smc for quite a long time now, and you must use products for use with smc, Not all fiberglass resins will work with smc.
Old 10-12-2006, 08:13 PM
painting fiberglass
I'ts a fiberglass corvett body on a go cart frame. A friend of mine is in the omar jett's and he drives it in parade's. Thank's for the info i think i'll epoxy first and if i need too i'll use 2k .
Cutting glass by sandblasting, Urban Myth? MARTINSR Body - Exterior 61 01-03-2015 08:48 PM
chopping top on truck levittmotg Body - Exterior 20 03-22-2006 08:42 PM
fiber glass VS metal Judd Lund Body - Exterior 11 09-22-2005 08:23 AM
windshields bill66di Body - Exterior 15 07-31-2004 07:31 AM
How to on Fiber Glass Parts SnapCase Body - Exterior 10 05-23-2003 04:02 PM
