Painting a Flat black over an oem type paint job - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2010, 11:24 AM
I about a 56' Ford F100 a couple of weeks ago thats in great conidtion minus the exterior paint. There's no rust, it just needs to be repainted due to being faded from sitting in the sun. I was wondering if I could spray a flat black over the current paint if I gave a good sanding? It's not going to be a show piece, more of a weekend cruiser.
Old 06-17-2010, 09:01 PM
It depends on what type paint is on the truck. If it's lacquer,
then it wouldn't be advisable to recoat without stripping.
Try rubbing it with a rag wetted with a solvent, and see if the
paint comes off; if so, then it's lacquer.
If the truck has been painted with enamel, then you can do the
body work, sand the existing paint and recoat it with an enamel
or urethane. Not the best way, but it's done everyday.
I'd paint it with a satin black instead of flat. Just my opinion but
satin looks better to me....
Old 06-17-2010, 09:51 PM
Rag top bird's Avatar
Hot rods are still the king
I have use SEM hot rod black many times never had any problems it is a satin black like Runnin'OnEmpty posted on and apply medium wet coats
Flat Black Paint for Fiberglass. scrimshaw Body - Exterior 6 02-25-2008 08:03 AM
Need advice on a paint job tishmomo Body - Exterior 36 01-15-2008 11:19 AM
Painting flat black with a roller fiscus Body - Exterior 21 06-10-2007 09:01 AM
how to paint flat black on spike TV roddinron Body - Exterior 6 09-04-2006 09:06 AM
Flat Black Paint trick66 Body - Exterior 10 03-15-2003 05:13 PM
