You have a pattern that should blow up larger quite well....take this image to your local trim and graffic's shop (I assume you have one near by and they can cut you a stencil...you would need to mask of for each color, but that would be the easiest, unless your talented with an air brush. I've used graffic's from companies in the past and had good results...for full flames on a vehicle, hood and both sides about $160.00.
Ray
