-   -   painting globe and anchor design on hood of truck (http://www.hotrodders.com/forum/painting-globe-anchor-design-hood-truck-227250.html)
Nuck Chorris 12-16-2012 08:18 PM
1 Attachment(s)
My nephew wants me to paint a globe and anchor on the hood of his truck, it's a 90s ranger. Colors are JDBB hood and tops of fenders to body line. Red globe and anchor. Trouble is, I'm not quite sure what the best order or method is to mask off for this complicated of a design. What would you do?
69 widetrack 12-17-2012 12:55 PM
You have a pattern that should blow up larger quite well....take this image to your local trim and graffic's shop (I assume you have one near by and they can cut you a stencil...you would need to mask of for each color, but that would be the easiest, unless your talented with an air brush. I've used graffic's from companies in the past and had good results...for full flames on a vehicle, hood and both sides about $160.00.
Ray
Nuck Chorris 12-17-2012 03:32 PM
I've decided that cutting that pattern out would be too much work. So I'm going to fill in the wings, anchor, and leave the America's so that it's not just a circle. That is doable with a pattern, hobby knife, and some tape.
Nuck Chorris 01-21-2013 01:54 PM
3 Attachment(s)
so anyway got the Marine Corps logo painted onto the Ranger hood. Took about seven hours to get the design printed out, cut out, taped, and painted. It would have worked out much better if we had thin tape, but we only had 1 inch tape which we ripped down into strips with an xacto knife. We were pretty satisfied with the result.
