painting globe and anchor design on hood of truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2012, 08:18 PM
My nephew wants me to paint a globe and anchor on the hood of his truck, it's a 90s ranger. Colors are JDBB hood and tops of fenders to body line. Red globe and anchor. Trouble is, I'm not quite sure what the best order or method is to mask off for this complicated of a design. What would you do?
Old 12-17-2012, 12:55 PM
Faith - Respect - Trust
You have a pattern that should blow up larger quite well....take this image to your local trim and graffic's shop (I assume you have one near by and they can cut you a stencil...you would need to mask of for each color, but that would be the easiest, unless your talented with an air brush. I've used graffic's from companies in the past and had good results...for full flames on a vehicle, hood and both sides about $160.00.
Ray
Old 12-17-2012, 03:32 PM
I've decided that cutting that pattern out would be too much work. So I'm going to fill in the wings, anchor, and leave the America's so that it's not just a circle. That is doable with a pattern, hobby knife, and some tape.
Old 01-21-2013, 01:54 PM
so anyway got the Marine Corps logo painted onto the Ranger hood. Took about seven hours to get the design printed out, cut out, taped, and painted. It would have worked out much better if we had thin tape, but we only had 1 inch tape which we ripped down into strips with an xacto knife. We were pretty satisfied with the result.
ID:	70776   Click image for larger version
ID:	70777   Click image for larger version
Very cool hood hinge design on Mercedes CL63 MARTINSR Hotrodders' Lounge 21 10-18-2009 10:46 AM
Console Design - AD Truck Houston54 Interior 6 01-15-2009 05:26 AM
Golden Globe censors asleep? cboy Off-Topic 5 01-13-2009 06:36 AM
Tips on painting truck roof and hood? LanceM Body - Exterior 8 07-27-2006 01:42 AM
How to design hood holder-open-er rwruther Body - Exterior 12 07-10-2004 01:03 AM
