painting head gaskets? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2003, 06:40 PM
I figured out my low compression problem was due to blown head gasket and not the heads. (for those of you following my problem )
I bought new head gaskets and i was told by the Kragen worker to spray paint them with aluminum paint before putting them on, is this a good idea? I asked someone else and they said they had never herd of it.
Old 12-14-2003, 06:44 PM
mstngjoe's Avatar
What kind of gaskets are they?
Unless they are bare copper/metal, they should go on dry. When all else fails.....follow the gasket makers instructions.
Old 12-14-2003, 06:49 PM
Years ago...it was common practice to spray head gaskets..they even made a copper gluey mess for the purpose (still do).
I have painted many, many sets.
Stopped about 10 years ago.......
Go by the head gasket manufacturers recomendation.....
Old 12-14-2003, 07:21 PM
BOBCRMAN@aol.com's Avatar
Most modern head gaskets are installed dry. But, read the instructions!!!!!
Old 12-14-2003, 07:44 PM
thanks for the fast replies!
Old 12-14-2003, 10:11 PM
That's what we used to do years ago with the cheap steel shim gaskets. Paint it with aluminum paint, let it dry for a while, then spray it again right before you install it. That was before they made the spray copper-coat stuff. Definitely follow the gasket manufacturer's instructions though. Make sure your block & head surfaces are not eroded at the point where the gasket failed.
Old 12-15-2003, 06:04 AM
Wiki Edits: 49
Did exactly that this weekend when installing heads on the hemi for the truck. Early hemi head gaskets don't have a sealed coating on them and require a coat of that very same coper gooey, sticky gunk to seal properly. (As per the gasket makers directions).
Like the man said, spraying head gaskets used to be done on a routine basis, but modern technology eliminated the need to do so (providing you're using modern head gaskets).
Centerline
http://www.hotrodsandhemis.com
