Sand them (180) but NOT down to the plastic.
prime, not putty ,if anything still sticks out (like a gouge) then putty that and prime again. but try not to leave a heavy buildup of primer.stop sanding if you hit plastis (it'll fuzz up and be hard to get rid of) you can sand it almost all off . In other words ...use the primer as a putty it'll be more flexable and easier to sand |
If you are spraying a base clear metallic it has to be smooth or the metallic will pool into the creases and look darker in those spots, especially a silver or a gold, white will also show surface imperfections but it will be less noticeable, a black you can get away with much more. I also like spraying on rainy days, I use window cleaner instead of wax n grease remover because it flashes off faster, cheap tack cloths are way too tacky, cheap Viva paper towels work great for me, and a water trap on your compressor is a good investment, if you can't afford a nice one get a cheap one, and use the disposable filters on your gun. http://www.kbs-coatings.com.au/asset...es/sgf-300.jpg |
your way ahead of me,I'm still priming little pieces
I ALMOST forgot the peice on the right in the pic where the peices are hanging on the wall. Was just about to disassemble my gun and clean it and realized it was still hanging there. I only used half a quart of paint to paint all of those peices, 4 coats (8:4:1 ratio so 8 ounches of paint turn into 13, and I spray really thin to avoid runs since I'm a noobie). I'm hoping it's going to be halfway durable
Next comes clear.
I've done that many times.
