Painting the inside of the trunk - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2002, 08:53 PM
Post Painting the inside of the trunk
The trunk panel I am using to replace my damaged one is a junkyard part. I would like the inside part to match the external part. It seems too intricate to sand. How should I go about refinishing it? Can I spay it with a DuPont Sealer and then paint over it or do I have no choice but to sand it?
Old 06-18-2002, 09:53 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
bead blast it or use a wire brush then seal it and paint it. I recomend the blasting, its easier, less marring, and it gets all those hard to reach places. you can get a handheld blaster for under $50 that you just hook up and air hose poor in your abrasive and spray, its cheap it works and its reusable.
Faust
Old 06-19-2002, 05:06 AM
Post
After I bead blast, can I use the DuPont Epoxy Primer as a sealer? Or should I go out and get the DuPont Vevia (Wrong spelling) sealer that requires no catalyst?
Old 06-19-2002, 11:09 AM
Post
The epoxy primer is it a primer/sealer, or just a primer? Not familiar with dupont paints. I use PPG products, DuPont isn't available here.
If its just primer, go out and buy a sealer, primers are thin and porus and will not seal the metal as needed. A sealer is thick and will/can protect against prolonged exsposure to the elements.
Faust
Old 06-19-2002, 09:09 PM
Post
Listen to this.............I told the guy in the supply shop I was using DuPont Centari and he gave me an Epoxy Sealer and catalyst made by PPG. It's DP402. I didn't realize this until I got home. Did this guy give me the wrong stuff?
Old 06-20-2002, 05:58 AM
WoodsEdge's Avatar
Post
Hey Faust,
Where can I pick up one of those bead blasters, I need one.
Thanks, Jack
Old 06-21-2002, 05:04 PM
Post
Heeeeeeeey Jack, not sure where you are. Try the Snap-on man, or your local paint shop/supply house like lows or home depot. I bought mine from a autobody repair supply house, I'll go to the shop tomorrow and get the number for you, along with a few other supply books you should get, they are free, so why not havem in the shop, hehe
Faust
Blocking and filling underside of hood and trunk, I hope it is worth it. Ripped Body - Exterior 4 08-22-2007 09:37 PM
Almost finished fitting / shaping f/g trunk, starting the hood Ripped Body - Exterior 3 05-05-2006 05:50 AM
Battery in the trunk Question.... tm454 General Rodding Tech 7 03-03-2005 09:29 AM
Trunk Caprice Body - Exterior 2 02-15-2005 06:54 PM
First time replacing a trunk bigfred1958 Body - Exterior 0 08-30-2004 11:10 AM
