painting my Eldo Convt - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2012, 07:52 AM
How Warm does it need to get to paint my car with Acrylic Lacquer in my garage. Thanks
Old 10-16-2012, 07:09 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
Back when I frist started doing bodywork and lacquer was being used daily I painted in a small rented shop at temps of around 50.
Old 10-16-2012, 08:08 AM
Ahhh painting with Lacquerm and an Eldo convertible, both those bring back memories. A green 76', yep memories.
All I know is I painted it year round in a "shop" that was no more than a big garage. No heat, other than a home made heat lamp (six flood lights basically) and I made a living and fed the family year after year.
Now this was in the SF bay area where it goes from 40's to the 90's throughout the year.
Old 10-16-2012, 12:33 PM
50-60 is reasonable; if this has an activator, I believe some will say they stop working around 50* YMMV
Old 10-16-2012, 01:22 PM
novafreek6872's Avatar
Nova Guru
Question is WHY??? There are so many better options to using Lacquer for about the same money!!
Old 10-16-2012, 03:49 PM
swvalcon's Avatar
The only reason I can see to use lacquer in this day and age is if its a real rare car and your trying to restore it to as close as possible to factory. Otherwise theres no reason to use it.
Need help with eldo caliper problems? s10quint Suspension - Brakes - Steering 1 07-20-2012 12:56 PM
Eldo stumbles pmeisel Transmission - Rearend 2 07-02-2007 06:23 AM
'93 eldo touring 4t80e problem commonman Transmission - Rearend 11 12-17-2005 11:39 AM
Newbie with a 65 Galaxie Convt. skijones Introduce Yourself 2 08-19-2005 07:29 PM
Installing my 1st convt. Top bigfred1958 Interior 37 02-20-2005 07:01 AM
