Painting my truck. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2009, 07:41 PM
Painting my truck.
I have painted many cars and trucks over the years. I'm getting ready to paint my truck and I want to paint it in piece. The bed is off so I want to spray it. Then the cab without the doors. Then paint the doors and hood last.
I've been told not to because the color will not match.
But I think if I put two to three coats on each panel and keep them even it should turn out fine. I'm painting it PPG Curious yellow.
It's a solid color so I think it would be OK.
Just checking to see what you guys think.
Old 02-01-2009, 09:19 PM
302 Z28's Avatar
Mix all your paint and reducer in one container all at one time. As you are painting draw material from that one container, keeping it agitated. I know it will make for a long day, but try and paint everything at once. Most solid non metallic colors do not have a matching problem while painting in pieces. I am not familiar with that particular shade of yellow, but yellow could be the exception. try and keep everything consistent, air pressure, spray pattern, number of passes, and be patient.
Vince
Old 02-02-2009, 01:38 PM
Thats the problem I don't have the space to spread the parts all out and paint them all at once. I would like to paint the bed first. Then the cab. Then the doors and hood.
This is the color I'm using.
Help! what frame to put under a chevy 1 1/2 ton truck? Riley Hotrodding Basics 10 02-15-2009 08:15 AM
Painting a truck..see if i'm on the right track shad9876 Body - Exterior 5 09-16-2008 10:27 AM
replacement pickup truck - your advice please jojo99 Engine 3 04-28-2006 04:48 PM
replacement pickup truck - your advice please jojo99 General Rodding Tech 6 04-28-2006 01:18 PM
little eddy-1950 chev truck lowbux Introduce Yourself 5 03-05-2006 11:47 AM
