thank you sir.. losts of work and alot more to go.. ive been doing it all myself no help.. lol
i was thinking about mixing a pearl in the clear to spray over the green base.. like a ghost pearl.. kinda like i did here on my racing mower its a black base with a blue pearl in the clear..
Very nice looking mower and Kudos to the work on your frame that you've done...but...instead of putting the green pearl in your clear and if I remember correctly your using a Dupont base coat...consult your Dupont jobber and see if they can mix you a mid coat that's a base coat clear and put the pearls in that...If they question you, ask them what they use for a mid coat clear in Duponts "Hot Hues" collection. I know it's a transparent base coat with pearls in the mid coat. This would make your life a lot easier.
Ray |
ok your going to have to show me what your talking about lol.. the green im using now has pearl in the mix but i want to just give it a crisp deep color in the sun.. the color is called Emerald Green Metallic Clearcoat
that mower is fast lol ive had it to 75mph but scared the poo out of me haha it makes well over 70hp with a real mower engine i have a video on youtube doing some testing if you want me to post it |
I'm very familiar with GM W/A177B...but what I'm talking about is to not put the pearl in the catalyzed clear, you but it in a transparent base coat, just like the pearl that they but in the mid coat clear on the Cadillac tri coat pearl white or there "Hot Hues" collection...If you talk to your Dupont Jobber ask them to make up a mid coat similar to the Caddilac color and then spray it over top your green 177B...it will make your green pop even more...if you like I can make some calls tomorrow to my local Dupont jobber (whom I know quite well) and get you a formula...let me know if your interested...it's much safer to do it this way...it's cheaper than putting it in a catalyzed clear coat...and the effect is much more significant...let me know, I'll check my reply list in the morning...(it's almost 2 AM where I'm at now) but if you let me know, by 1 or 1:30 my time tomorrow, I'll have a mid coat formula for you and the formula will be simple.
I need to get some sleep so talk to you later my friend. Ray |
I would love to try some of the SPI product...I know you as well as others on this site swear by the product. I have no reason to doubt you but it's difficult for me to recommend something I haven't tried...Maybe I should PM Barry and see if it's even possible to ship to Canada with respect to VOC laws up here. Sure would love to try it, does is sand as well as a quality 2K primer like PPG's K38? |
Will have your answer by early afternoon. Best to you and your project. Ray |
Part # Volume 150K-USG B/C Balancer 50% 175K-USG B/C Binder 50% There are different types of green pearl and they are powdered pearls. Part# Amount 10085 Moss Green Pearl .4 grams per quart 10095 Super Green Pearl .4 grams per quart 10055 Gold Pearl .4 grams per quart [B]The amount of Pearl you use is to your own preference, keep in mind that you do not need much to give you a vivid Pearl effect. I would recommend that you have your jobber mix up a small amount of each and check the Pearl effect in the sunlight. I included the Gold part # because I was thinking that it may be a nice touch to the W/A 177B paint your putting down as a Base. With the right amount of Gold Pearl, only the high points of your truck would look electric when in the sun...In the shade, it would be the regular green.[B][ This Mid Coat would use the same reducer as your W/A 177B Green Base Coat and is reduced 100% or 50 parts base, 50 parts reducer. A spray out panel would also be recommended so you can see how many coats of Mid Coat will give you the effect you want. Also, clear the spray out panels to get the full effect of the Pearl Mid Coat. I hope this helps, and remember, it doesn't take much Pearl in the Mid Coat to give you effect in the sunlight so have the jobber mix a small amount first and decide if you need more or less Pearl...It's your call, but much cheaper and easier to repair if you ever need to than Pearl in a catalyzed clear. Any other questions, please let me know. Ray P.S. I would have gotten you a Chroma Premier formula but it is discontinued in Canada due to VOC regulations and I had to go through Dupont's archives to find a Chroma Base formula. In other words, I ran out of time and I promised you 1:30 PM my time. |
That's right, paint a test panel first, apply your base coat, and put on one coat of the pearl midcoat over the entire panel, let if flash, mask off a section about 4 inches long and apply another coat of the pearl midcoat, let it flash, mask off another 4 inches and then spray the pearl midcoat over the remaining panel, if you have room on your test panel do it one time, let it flash and remove all the masking paper, clear the entire panel and take it out in the sunlight. This way you will see the effect of 1,2,3 and 4 layers of mid coat and what effect sunlight has on it.
When you spray the midcoat, spray it the same way you would when spraying your truck. Generally 2 coats of pearl midcoat will give you the desired effect. This is dependent on how heavy you apply the mid coat. I recommended .4 grams per quart because pearls are sunlight sensitive and when they don't have any pigment in the mix, the true effect is realized. I would try the gold...I think it would really pop in the sun. Ray |
| Painting my truck. | xtrmes10 | Body - Exterior | 2 | 02-02-2009 01:38 PM |
| Painting PU Truck Bed Help | jberry | Body - Exterior | 8 | 11-18-2007 05:45 AM |
| Painting Truck | Rebel20o7 | Body - Exterior | 1 | 01-17-2007 06:16 PM |
| Painting crash helmets info please | Steve UK | Body - Exterior | 9 | 10-12-2005 09:05 AM |
| Painting Panels on truck | Bluepen | Body - Exterior | 1 | 03-05-2003 09:32 AM |
