Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Painting my twin turbo camaro ( helppppp)
Old 09-15-2012, 05:50 PM
Project89's Avatar
Project89 Project89 is offline
I can't recommend enough to go to a local paint store and buy all the products from them along with getting the tech sheets so you know what you are working with. They often have a "cut to the chase" sort of data sheet too that isn't so complicated. But honestly, to be buying products from different web sites and throwing it all together in a pot, you are going to be stepping up the learning curve big time!
Get it all from one source along with the use information and you are going to be eliminating a LOT of headaches.
thats why i figured id either use the summit brand stuff i have, or get all new stuf fin black from eastwood, the only thing that wouldnt be comming form eastwood would be the pearl.
with the pearl isnt that a pretty much universal thing u just mid in with the clear ? if i were to do it as bc/cc instead of single stage ?
my idea is to lay down the black base coat then mask off the stripes and shoot the stripes witht he clear/pearl mix , then after shoot the 3-4 coats of clear over the whole thing
