-   -   Painting my twin turbo camaro ( helppppp) (http://www.hotrodders.com/forum/painting-my-twin-turbo-camaro-helppppp-224017.html)
Project89 09-15-2012 01:07 AM
as some of u rember last year i started to paint my car using the rolled on rustoleum. it was a temp paint job till i could spray the car. well i only ever managed to get the hood done , and the rear deck. the stuff help up great for a full year in direct sunlight.and still looks as good as the day i put it on.
but im not going to finish the car off with it im going to strip that stuff off and apply a black epoxy primer ( eastwood) and then spray it with a single stage eastwood boulevard black
what are u guys thoughts on this paint
here is the epoxy primer
Epoxy Primer and Catalyst Kit Black Gal
and here is the paint
they also have this in a bc/cc instead of a single stage which i thought about getting and tossing in some blue or red pearl in the clear just enough to give it it a slight color tint at certian angles
also can anyone see a difference between the boulevard black and this one??
http://www.eastwood.com/ew-midnight-...int-96-oz.html
thoughts, suggestions?
Project89 09-15-2012 02:17 AM
i was thinking maybe something like this to do ghost stripes on the car
Sparkling XXX BLACK metallic pearl spray gun PPG dupont Flames Skulls Airbrush | eBay
thinking about it i dont think doing the whole car with a blue or red or even copper tint would look the way im thinking it would
MARTINSR 09-15-2012 11:05 AM
I can't recommend enough to go to a local paint store and buy all the products from them along with getting the tech sheets so you know what you are working with. They often have a "cut to the chase" sort of data sheet too that isn't so complicated. But honestly, to be buying products from different web sites and throwing it all together in a pot, you are going to be stepping up the learning curve big time!
Get it all from one source along with the use information and you are going to be eliminating a LOT of headaches.
Old Fool 09-15-2012 12:11 PM
SPI epoxy #6600 and single stage flat black # 2201-1 would be my choices.
Pricing Info
Old Fool 09-15-2012 12:17 PM
Learn more about the SPI flat black single state
SPI Flat black polyurethane single stage photos when mixed 6:1
SPI Flat black polyurethane single stage test panel photos when mixed 4:1 and 8:1
mitmaks 09-15-2012 03:48 PM
Spend the money and get automotive paint. House paint is for houses not for the car
Project89 09-15-2012 06:46 PM
Pricing Info
i dont want flat black for the car
i am getting automotive paint
anyone have any feedback on the eastwood stuff ?
other then that i already have 1 gallon each of the summit paints in metalic blue and silver , my original plan was to do a 2 tone paint job but ive changed my mind, if the eastwood stuff is garbage i may just paint the car metalic blue with silver stripes with the sumit paint i already have
Project89 09-15-2012 06:50 PM
thats why i figured id either use the summit brand stuff i have, or get all new stuf fin black from eastwood, the only thing that wouldnt be comming form eastwood would be the pearl.
with the pearl isnt that a pretty much universal thing u just mid in with the clear ? if i were to do it as bc/cc instead of single stage ?
my idea is to lay down the black base coat then mask off the stripes and shoot the stripes witht he clear/pearl mix , then after shoot the 3-4 coats of clear over the whole thing
mitmaks 09-15-2012 07:41 PM
Hopefully this video will answer your question about cheap paint...
