Painting my twin turbo camaro ( helppppp) - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2012, 12:07 AM
Project89's Avatar
as some of u rember last year i started to paint my car using the rolled on rustoleum. it was a temp paint job till i could spray the car. well i only ever managed to get the hood done , and the rear deck. the stuff help up great for a full year in direct sunlight.and still looks as good as the day i put it on.
but im not going to finish the car off with it im going to strip that stuff off and apply a black epoxy primer ( eastwood) and then spray it with a single stage eastwood boulevard black
what are u guys thoughts on this paint
here is the epoxy primer
Epoxy Primer and Catalyst Kit Black Gal
and here is the paint
they also have this in a bc/cc instead of a single stage which i thought about getting and tossing in some blue or red pearl in the clear just enough to give it it a slight color tint at certian angles
also can anyone see a difference between the boulevard black and this one??
http://www.eastwood.com/ew-midnight-...int-96-oz.html
thoughts, suggestions?
Old 09-15-2012, 01:17 AM
Project89's Avatar
i was thinking maybe something like this to do ghost stripes on the car
Sparkling XXX BLACK metallic pearl spray gun PPG dupont Flames Skulls Airbrush | eBay
thinking about it i dont think doing the whole car with a blue or red or even copper tint would look the way im thinking it would
Old 09-15-2012, 10:05 AM
I can't recommend enough to go to a local paint store and buy all the products from them along with getting the tech sheets so you know what you are working with. They often have a "cut to the chase" sort of data sheet too that isn't so complicated. But honestly, to be buying products from different web sites and throwing it all together in a pot, you are going to be stepping up the learning curve big time!
Get it all from one source along with the use information and you are going to be eliminating a LOT of headaches.
Old 09-15-2012, 11:11 AM
Old Fool's Avatar
SPI epoxy #6600 and single stage flat black # 2201-1 would be my choices.
Pricing Info
Old 09-15-2012, 11:17 AM
Old Fool's Avatar
Learn more about the SPI flat black single state
SPI Flat black polyurethane single stage photos when mixed 6:1
SPI Flat black polyurethane single stage test panel photos when mixed 4:1 and 8:1
Old 09-15-2012, 02:48 PM
mitmaks's Avatar
Last journal entry: Grille
Spend the money and get automotive paint. House paint is for houses not for the car
Old 09-15-2012, 05:46 PM
Project89's Avatar
Pricing Info
i dont want flat black for the car
i am getting automotive paint
anyone have any feedback on the eastwood stuff ?
other then that i already have 1 gallon each of the summit paints in metalic blue and silver , my original plan was to do a 2 tone paint job but ive changed my mind, if the eastwood stuff is garbage i may just paint the car metalic blue with silver stripes with the sumit paint i already have
Old 09-15-2012, 05:50 PM
Project89's Avatar
thats why i figured id either use the summit brand stuff i have, or get all new stuf fin black from eastwood, the only thing that wouldnt be comming form eastwood would be the pearl.
with the pearl isnt that a pretty much universal thing u just mid in with the clear ? if i were to do it as bc/cc instead of single stage ?
my idea is to lay down the black base coat then mask off the stripes and shoot the stripes witht he clear/pearl mix , then after shoot the 3-4 coats of clear over the whole thing
Old 09-15-2012, 06:41 PM
mitmaks's Avatar
Hopefully this video will answer your question about cheap paint...
Twin Turbo's srwilson8074 Engine 11 02-02-2012 12:45 PM
T3 twin turbo 1967chevelle454 Engine 0 02-04-2009 12:20 PM
twin turbo 86 IROC camaro biggunn770 Introduce Yourself 2 02-22-2008 07:09 PM
twin turbo ? mbriner Engine 7 06-08-2006 06:15 PM
85 camaro with 383 stroker with nitrous oxide or twin turbo? camaro dan Engine 0 10-08-2002 06:18 PM
