Painting a new fender - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2005, 02:03 PM
I just installed the new inner fender on my truck. It looks pretty good. I wet sanded the factory dip with 320, washed and dried it, applied auto body primer from a can, then painted it black from a can. Instead of sanding the primer, I buffed it with a soft cloth (this worked very well). I'd post photos of it, but don't know how. NEXT, the new fender...
After talking to a friend that used to be in the coatings industry, I have decided to paint the new fender in my basement. I will shoot it from outside of the booth (through a hole in the curtain), which will be adequately vented into an outdoor air chamber that has an air filter to catch the particulates.
I'll be using an air compressor and standard spray gun. Not sure what nozzle is currently on the gun, but I plan to use a 1.3 per MARTINSR's guidelines.
I need to match the existing dark metallic blue and apply a clear coat over that. I don't want to mess with high VOC/low solvent paint and risk a bad paint job. I've gotten pretty good with the spray cans.
Q1: Given the color and that I'm only painting one fender, what type of paint should I use for the base coat and clear coat? I was thinking Laquer, because I can sand it down if I mess up.
Q2: What is the best way to color match my existing paint? I could take the old fender with me... Do I need to compensate for paint fade? How?
Q3: Does it matter which paint supplier I buy the paint from?
Old 10-21-2005, 03:13 PM
roger1's Avatar
I wouldn't use lacquer on a truck. The ONLY thing I would use lacquer for is if I wanted to have the orginal type of paint on an older vehicle that I was trying to be 100% correct on. And, I would NEVER use a lacquer primer.
If you are wanting to go with an inexpensive paint, I would go with the PPG Omni MTK single stage or MBP base coat and Omni Urethane Clear. It's an econo paint cheap enough to sand off and do over yet would be much more durable than lacquer.
Don't know if your truck is base/clear or single-stage but I'd go with which ever the factory did on the original.
I painted about half of a 91 Ford truck last year with Omni MTK and it came out pretty nice. The truck wasn't perfect so I didn't need to put top quality paint on it. I just gave the paint supplier the color code and it was a pretty darn good match (metallic green).
If you like Dupont their econo line is called Nason. Should be about the same as PPG Omni.
Old 10-22-2005, 11:42 AM
Non-factory paint color matching
Thanks for the suggestions on paint.
Sorry I forgot to mention that my truck has been repainted (poorly). The original color was a medium blue metallic (nice). The current paint job is a dark blue metallic.
I'd like to repaint the entire truch eventually, but for now, I just want the new fender to match the rest of the truck. How would I go about choosing the right color/tint?
Nice (65?) 'Vette.
Old 10-22-2005, 11:52 AM
roger1's Avatar
Nice (65?) 'Vette.
Thanks! The Vette is a '66. Check out my gallery for detailed pics:
http://hotrodders.com/gallery/showga...0/ppuser/17782
I am working on a '69 as we speak.
If you can't get a formula from the shop that put that color on the truck, You will have to take the truck to a paint supplier that can scan the color and come up with a formula for it. I have never done this so I don't know how accurate it is. Others on this forum I am sure can offer more advice on this.
Sounds like you will have to strip the truck later when you do paint the entire truck. You don't want to do more than one re-paint without stripping.
Old 10-23-2005, 04:32 PM
Nice shop!
My dad would love the '69 Corvette. He's nuts about yellow cars.
I have a gas-powered Cox model of a 65 that is red.
The truck will definitely need to be stripped (to me that means sanding down to the original color). The repaint was applied directly over the old paint. Judging from the peeling, I don't even think they sanded/dewaxed/deglossed it. I'll repaint the whole truck eventually...
Old 10-23-2005, 10:00 PM
Take the old fender to your paint supplier, explain what you're trying to do then get his advice. Being that you don't know what the color code is and what paint was sprayed I wouldn't get your hopes up for a perfect match. Do the job right when it comes time to do the whole truck and strip it right down to bare metal if this is an older truck. Use good quality materials: epoxy primers, urethane surfacers, and urethane basecoat/clearcot. I wouldn't expect the rattlecan primer and paint to last very long on that innerfender. Bob
Old 10-24-2005, 02:13 AM
Thanks, Bob. A guy at the place I got the inner fender and fender from said the dip coating is guaranteed (or good for?) 25 years. I hope this makes up for the cheesy paint I used over it...
Prepping and painting new/dipped parts? tcruise Body - Exterior 5 10-17-2005 12:52 AM
Painting Firewall, Fender Aprons? Kampr Body - Exterior 5 09-30-2005 01:53 PM
painting around fender welt jhenry Body - Exterior 6 03-29-2005 07:34 AM
Painting Fender - How much paint needed? 64Joker Body - Exterior 4 03-28-2005 08:31 PM
I need help with fender patch panels. unstable Body - Exterior 6 03-28-2005 08:27 PM
