Hotrodders Bulletin Board > Tech Help> Body - Exterior
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 03-30-2005, 12:53 AM
jchiesa jchiesa is offline
Painting New Fiberglass body panels
I am currently getting ready to spray some fiberglass panels for an 18 wheeler. The fiberglass hood is being purchased new from an aftermarket dealer. Once the hood arrives will I need to prime it or can I just sand it with some 1000 and spray on? I will be using acryllic enamel by the way.
Thanks,
jchiesa
Old 03-30-2005, 03:26 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Wiki Edits: 3
Scrub it
One of the things is that new fiberglass parts can have mold release wax on them so you need to scrub that part with ammonia and hot water till you are tired of scrubbing..
Then wipe it down with acetone to make sure all the wax is gone..
Watch for pinholes in the part..sometimes in spite of the best efforts there will be little air bubbles in the mold..to fix this use a primer surfacer..then spray it out with whatever you normally use in your shop..
OMT
Old 03-30-2005, 08:39 PM
Thanks a TON! I will wash it as you said before anything else. If the surface is already smooth, should I still sand it? I know that sanding promotes adhesion but I also don't want to muck up the job before I even spray.
Thanks again!
Old 03-30-2005, 09:07 PM
Bee4Me's Avatar
Bee4Me Bee4Me is offline
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
It will probly have a smooth gel-coat finish which does need scuffing or sanding 400-600 before painting IMO. On the hood,It would be worth while to long block it before you shoot paint. Some imperfections could be in it that the naked eye won't see and as soon as you paint it will stick out like a sore thumb.My 'glass hood on my Ram had this happen and the upfitter had to replace the hood a year later at his expense. I'm not a pro on 'glass and I'm sure there are other ways to skin this cat so, hang loose and get some more oppinions before shooting a acrylic enam. and having to redo it.
Old 03-30-2005, 09:16 PM
Wiki Edits: 3
Painting fiberglass
Paint will no tstick to slick shiny gelcoat..at least not for very long..Soooo scrub the part with 3M scrubbers or wash and wet sand..whatever you do get the wax off and get rid of the shiny before painting..a good quality primer or primer surfacer will take care of the deal from there and after that it is the normal bc/cc finish..
Properly prepared fiberglass parts are dull (no shiny anywhere) then apply paint..
OMT
Old 04-20-2009, 10:02 AM
pavetim pavetim is offline
Priming fiberglass panels?
I was going to use southern polyurethanes products on my firebird. I'm going to strip everything down and use epoxy on the metal, then 2K urethane, then possibly poly primer and then seal. My question is would I be better off using the same steps on the fiberglass panels or just use 2K urethane? What would you guys do diff on the fiberglass panels? Thanks.
Old 04-20-2009, 02:14 PM
pompano100 pompano100 is offline
New Member
primer
One great solution would be to use the zero rust primer paint together with zero rust prep. You would mix the prep with water, its a phosphatizer and not an acid, this will bring the metal to ph6 and then spray with zero rust. *********** for more information
Last edited by OneMoreTime : 04-20-2009 at 02:45 PM. Reason: Advertising. Please see: commercial posting guidelines.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "Painting New Fiberglass body panels"
ThreadThread StarterForumRepliesLast Post
fiberglass door panels, dash, center console, sub enclosure, amp rackliftedbowtieInterior7409-15-2011 12:36 AM
"Basics of Basics" Sectioning a BodyMARTINSRBody - Exterior711-24-2008 01:04 PM
'55/6 Merc Fiberglass panelsSlipangleBody - Exterior604-08-2004 06:23 PM
fiberglass on body panels & aluminum sheetmetal replacementricerxBody - Exterior1106-02-2003 06:20 PM
Painting Panels on truckBluepenBody - Exterior103-05-2003 10:32 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
