Painting over base coat clear coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2011, 09:33 PM
Hello, I have a question. I painted my truck with a base coat clear coat, shot black and then a flat clear. I had problems with this. Now I am going to use Paint Shop by Dupicolor laquer. Will I need to prime first, or can I scuff and paint it? Wondering if I need to sand down through the clear.
thanks for any advice.
Old 10-13-2011, 10:11 PM
Last journal entry: Paint
What kind of problems did you have? What kind of paint did you use? If you used a urethane, I would repaint it with a single stage black urethane, you don't need the clear on there. You can color sand a solid color....I would stay as far away from that Duplicolor paint as I could after seeing the Mustang they painted on TV with it.
Old 10-14-2011, 08:46 AM
I think that's a bit excessive thing to do. As for me wouldn't do it either.
_____________
WAV to MP3 Converter http://wavtomp3converter.com/
Old 10-14-2011, 10:04 AM
TucsonJay's Avatar
Whatever you are spraying... sand with 600-800. Try NOT to go through the clear.
On a footnote... I've been doing this professionally for about 40 years. I've used lacquer for most of that time.
Lacquer products do not hold up very long compared to urethanes or catalyzed enamels. Depending on how you use it... clean it... and how much time it spends in the sun.. you could be repainting the car again in a very short time! :-(
Old 10-15-2011, 04:50 PM
Hey guys, thanks for the input. The problems we had were, when we shot the clear, the cab came out nice and flat, the fenders and bed came out satin finish... (sprayed at same time.) We tried this again 3 more times and that when I gave up. Can not figure out what the deal was.
I didn't really care after all the trouble if it was flat or satin, I just wanted one or the other. Then I heard about the Dupicolor paint on Two guys garage. They did some stuff with it and it looked pretty easy. What show was the mustang on, and what happened? This is the first Ive heard.
Old 10-15-2011, 08:33 PM
The Mustang was on Power Block TV. It looked really bad. There was a lot of negative comments about the paint on several different BBs.....They make single stage urethane hot rod black if that is what you are trying to do. You can scuff the clear and paint right over the top.
Old 10-16-2011, 10:10 AM
S10xGN's Avatar
Gotta love a turbo!
A while back, I painted some parts with 2k "Hot Rod Flatz" brand and noticed that they came out in varying shades of "gloss". I posted a query here and Barry responded back with info concerning this problem. The bottom line is that one must be very careful with recoat times. If you push the window, you'll get more gloss. After experimenting with this, I found it to be true. The sooner you recoat, the glossier the "flatness".
Russ
Old 10-16-2011, 05:17 PM
Thanks for the input. I had bought some of the dupicolor paint, have not opened it, I will take back and then buy the HotRod flatz. I was going to try it and then saw the Dupicolor paint.
thanks again
Old 10-19-2011, 01:58 PM
satin black
I would sand the clear with 500 wet. Re-coat with Kustom shop hot rod flatz(black) this product is a single stage with flattening agent already in it. Make sure you stir the color very well before adding hardener or you could have issues with gloss %. I just finished a 39 ford with this material,it worked out great!
Old 10-19-2011, 09:59 PM
Hey drybones, thanks for the tip. I am looking forward to trying it.
Help with PPG Deltron base coat paint and clear coat Please smithkustoms Body - Exterior 31 01-12-2012 07:43 AM
Question about touching up Base Coat/Clear Coat TR4AGuy Body - Exterior 0 10-08-2011 02:57 PM
Base coat/clear coat urethane over acrylic enamel mervhudson Body - Exterior 5 04-23-2011 10:56 AM
Couple of base coat/clear coat questions bigbrowndog Body - Exterior 17 11-05-2010 08:37 AM
laquer primer/ppg base coat/clear coat? dave mc Body - Exterior 5 10-11-2005 04:59 AM
