Painting over Epoxy Primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2005, 01:25 PM
I am coating the freshly stripped tub on my Early Bronco with Nason Ful-Poxy. I will still have some body work to do and patching. After I am done I want to paint the inside and underside with Nason Ful-Thane Urethane. I don't want to have to put on a high build primer on the underside, sand and then paint. Can I paint right on top of the epoxy primer? I assume that I will need to scuff the epoxy. Should I then coat with another coat of epoxy and then color or should I spray a coat of sealer before the color.
Old 10-10-2005, 04:40 PM
Scuff Meister
Every paint manufacturer has their own recommendations on what you can do and what you can't do. Unfortunately I'm unfamiliar with Nason products, I do know that PPG's epoxy primers allow you a 7 day "window" to apply primers,topcoat or what ever else you plan on putting over your epoxy. After 7 days they recommend you use this new fangled gadget called a scuff pad to abrade the primer before continuing on. Did you like that word? I would check with the manufacturer to be on the safe side!
Old 10-13-2005, 09:02 AM
Well I got an answer back from Nason. They recommend a sealer over the epoxy before the paint. They said that you can paint over the epoxy, but best results would be with a sealer. Maybe they are trying to sell more product or cover their tails, but I will seal over it to make sure.
Old 10-13-2005, 01:33 PM
I thought epoxy was a sealer?
Old 10-13-2005, 08:56 PM
mrcleanr6's Avatar
this is probably for adhesion reasons. yes you can use epoxy as the sealer itself. you just want to be spraying base on a somewhat fresh substrate rather than epoxy thats been sitting for awhile.
Old 10-13-2005, 10:52 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Frank I use epoxy mostly as a sealer and paint right over it without issues... With spi products I don't think you will have any issues, I have however used other company's epoxy namely Northstar, you can sand it after 12 hours, and must be top coated within 48 I think or you must scuff.. I did not think it was as good a product as spi FYI... It said to reduce up to 100% and at 50% it was like water... This is soley my opinon though.... When I spray spi it sticks like glue, and you have the 7 day recoat window, not to mention the rest of the things I can do that are not on the tech sheets, that I would not dare do with someone elses product....Its the only brand I use now...
If I have a big section of bare metal, of course it gets epoxy, but as I stated above I use it to seal up my work before bc/cc... I do my bodywork, 2k, and then seal it all with epoxy, and this is done on two separate days too... I let my 2k set a night sanded and in the sun if it permits the next day before I add the epoxy... I also let that set a full night and scuff any nibs out the next afternoon after the car has been in the sun if it permits.... bc/cc and works great for me..
Mrclean, I am curious too as to what you said... What really is the difference between the two.. I know Barry sells sealer, but I have never ask him about it, or even considered buying it since I keep epoxy on hand at all times these days... I was under the assumption ( I know that is dangerous) that they were very much similar, and would be a waste of my money.. Whats the gig bro???? I gotta know now
BTW sorry all, I seemed to have rambled on... It must be the fumes in my tiny garage nowdays... I can spit and hit the oposing wall
Matthew
Old 10-14-2005, 05:27 AM
mrcleanr6's Avatar
king....i have used barry's sealer. its a completely different product, its urethane based and very watery. if your using the epoxy to seal then there is no real benefit to switch to his sealer. the epoxy will work fine. i personally use a sealer before spraying base on anything. when i say sealer i just mean s fresh coat of something, primer, epoxy, sealer, etc. i find the base bonds so much better to the substrate if you do that. for everything i do, i dont exactly base things out then clear them. they tend to sit around for a week or two getting handled and artwork goes on. makes it more durable when doing tapeouts things like that.
Old 10-14-2005, 05:32 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Well I got an answer back from Nason. They recommend a sealer over the epoxy before the paint. They said that you can paint over the epoxy, but best results would be with a sealer. .
I'm surprised by this answer as well, I paint right over epoxy all the time
with no issues.
I do scuff it when it sits longer, like overnight.
I usually paint right over it with base as soon as the epoxy flashes
and it seems to seal as well as sealer.
I agree with Mathew on all his points.
Old 10-14-2005, 07:55 AM
Epoxy makes for a great sealer, people only run into trouble when they apply base too soon which causes loss in gloss and also when base is applied too late which makes for adhesion problems. Scuff when in doubt and don't use it as a wet on wet sealer- the thicker the stuff is applied the longer it takes to cure. At least that's the way I see it, maybe I'll get corrected if I'm wrong.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Self Etching or Epoxy Primer Ron M Body - Exterior 14 11-30-2010 06:23 AM
Epoxy vs Urethane Primer UKLuge66 Body - Exterior 41 11-23-2008 05:50 PM
Marine Epoxy Primer? rlackey Body - Exterior 10 03-24-2005 04:14 AM
Epoxy Primer lilgto Body - Exterior 2 02-23-2004 05:15 PM
