Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Painting with pearl
Old 11-03-2012, 05:05 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
That's correct...now check the black with the blue pearl in the sunlight after you mix it because that's the effect your going to get on the truck, remember a little pearl goes a long way. Also important is the test panel especially for the white pearl as the white pearl is on top of the black base and it won't take much pearl to give you a ghost effect. If I was doing the truck I would use blue ghost flames buy adding just a bit more blue pearl in the black I use for the flames...a much more subtle effect and it would keep your color motif more in line (Not just better effect, it's easier as well). Maybe do a test panel on blue flames...you just might like it better.
Ray
