Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Painting with pearl
  #18 (permalink)
Old 11-05-2012, 12:58 AM
inkfreak1976 inkfreak1976 is offline
Originally Posted by 19chevytruck90 View Post
I also looked at using an intercoat clear to carry the pearl but they don't use that at that shop and so don't carry it.
Any help I can get would sure be appreciated.
just fyi, omni does make a mid coat clear, or should i say ppg products. i think the shop is to lazy to order it. or you can over reduce your ppg clear. give one to two mid coats and then wait for full dry. scuff out with grey or finer, if with in 24 hrs no need to scuff, but to tape out and paint and detail air brush flames with in 24 hrs. when your not used to doing it is a over whelming task. thats why i would do a mid coat clear, doing the pearl in the black is a great idea that 69 stated, ive had bad luck with taping directly on fresh base. or you can simply just use the clear mixed normally just do a light wet coat, let dry. tape and go at it . i prefer to over reduce and do a couple of coats seems to give more depth to the paint. everyone does things differently. but i highly recommend the mid coat clear just to protect what you've already done. plus leaves you some wiggle room to take your time on the art work. good luck
The Following User Says Thank You to inkfreak1976 For This Useful Post:
69 widetrack (11-05-2012)
