painting pearl white - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2006, 10:43 PM
Hi guys a freind of mine wants me to spray his harley with pearl white paint. I never used pearl before and i'm wondering if theres a better solution to get a show quality paint job with white? Anytime i have used white it was with acrylics and it came out nice but since were just spraying a bike and cost isent really a factor since its just a bike i would really like to get some other opinions. What about clearing white i know it it yellows it a bit anyway around that? Thanks any suggestions would really be appreciated.
Old 01-22-2006, 10:51 PM
milo's Avatar
point on positive
You'll have fun if you take your time.
The biggest problem with white is keeping everthing clean as you go through the steps,,, wear a paint suit.
Have a peek in this link for motovation... you can do
it !
http://www.a2zautoforums.com/showthr...6&page=1&pp=20
>>another trick would be to use a "Factory Pack " mix for say Lexus pearl white ... nice soft pearl white in 2 parts with a midcoat with the pearl already figured for you
http://www.a2zautoforums.com/showthread.php?t=3832
Old 01-23-2006, 07:14 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
If the factory pack is too pricy,you can just use some gold pearl paste which is cheap for a small jar and it will last you quite awhile.Just do some test panels to get the mix to what you want. Start out light with about a 1/2 tsp. per sprayable qt. and add more if you need. If your shooting PPG,Try the Polar White. It's about as white as white gets. Dupont Chromabase would be a late model Toyota code. It's very white as well, I can give you the code later if you want.
Yellowing is usually from the clear itself as some do have a yellow tint with the UV additives. Dupont's 7500 Chroma is one as I've shot it on some aluminum intakes and it added a yellow tint to them.
Try Dupont's Nason 497. It's a really "clear" clear IMO. It's reasonable in price and sprays great.
Old 01-23-2006, 03:56 PM
You have never painted a pearl before. So many factory colors have pearl in them nowadays. Either mixed with the paint, or as a midcoat. Not really much different then spraying a metallic. The biggest problem I have with white is it is harder to see how its laying out and when clearing when you have a nice wet gloss on the entire car, but not to the point of running. White has always been my least favorite color to spray, I get snowblind when staring at it long enough. Yeah some clears do have a yellowish tint to them.
Old 01-23-2006, 07:24 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
The more pearl you add the more yellow tint the clear/intercoat takes on.. it is not the clear turning, it is the additives in it... You can always use an intercoat and apply as many coats as needed to get the desired effect... then top coat as usual the next day.
White Sealer nova69 Body - Exterior 5 08-26-2005 01:51 PM
Pearl white paintjob swoodard23 Body - Exterior 4 08-14-2005 09:25 AM
First paint scheme for '59 Caddy by me Nightrider Body - Exterior 54 07-05-2005 02:27 PM
Question about Snow white pearl from House of Kolor. Fordy8man Body - Exterior 6 03-20-2005 11:42 AM
White Primer VWFan Body - Exterior 27 10-13-2004 12:39 PM
