Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Painting a Pewter camaro quarter panel
Old 10-08-2012, 11:04 PM
paint dude paint dude is offline
Where exactly is your dent on your quarter panel, if towards the front part of it you may need to blend into your door. As far as color blender ( I'm speaking from Ppg, Dbc500) our product I use after the panel has been prepped and spot sealed, I spray a medium wet coat over entire panel, This way the paint isnt landing on a dry panel and it helps to avoid the hallow effect and you dont have paint dust that you have to tac before clearing. Have your local paint store look up your varients for your pewter if its wa382e you will have quite a few of them, seems like course and prime are most popular matches.This product also works great when your color is a shade off, you can mix it with your paint to make it more translucent so you can layer it out more giving you a better color match when you look at it from a side cast (flop) Clear entire panel. good luck
