painting plastic bumpers
Can anyone give me a primer on how to paint a new plastic bumper? My last painting experience was about 18 years ago. I only used Dupont products then; lacquer and acrylic enamal with hardner and epoxy primers were just getting popular so I am really behind times. Thanks for any help I receive.
I do a lot of bumpers, I do them all the same way.
Clean real good with a detergent like "Dawn" or "Joy" using a gray scuff pad. For extra safety you can follow that with a wipe down with Wax and Grease Remover. Scuff real good with a red scuff pad and a sanding paste like 3M "Scuff-it" A couple coats of adhesion promoter like "Bulldog" A couple coats of epoxy primer I usually go over the epoxy the next day with a scuff pad just to get it real smooth-but it's not necessary if it's smooth. (The epoxy really helps fight the rock chips) then paint as usual.
Yeah, I agree with J.C. I painted one a few years ago and just wetsanded with 600 grit and warm dish soapy water to remove any mold release, then clean, dry, wipe with cleaner, epoxy prime and paint. I didn't use any adhesion promoter but it is still on
I agree with these guys but if you are just doing the one bumper you can save your money on the "scuff-it" and just use comet and a red scotchbrite pad. Also, most plastic bumpers I do come with primer already on them so I just scotchbrite them with water and scuff it, clean with soap and water, then dry & tack, and then shoot with bulldog. Then comes my base; I shoot 2-3 light, but not dry, coats to get even coverage, and last but not least clear.
Just some quick tips: do not try to get total coverage on your base with the first coat or you will get fisheyes. Also, if it is a plastic bumper with primer already on it I would not use a solvent based wax and grease remover as it could lift the primer. |
| Help painting ABS plastic. | TurboS10 | Body - Exterior | 10 | 08-27-2012 09:30 PM |
| Painting Plastic Grills?? | Rightytighty | Body - Exterior | 4 | 04-26-2007 09:00 PM |
| Painting plastic inner grill | OperationMidnight | Body - Exterior | 4 | 10-07-2005 02:14 PM |
| Painting Metal Bumpers? Your tips, tricks, advice, experience. | Woogeroo | Body - Exterior | 1 | 02-21-2005 07:45 PM |
| Painting plastic | Lonestar | Body - Exterior | 2 | 09-07-2004 07:35 PM |
