I'd use an adhesion promoter before epoxy primer.
I'll second that* Epoxy on plastic works great. I've always used bulldog adh. promoter first but I'm curious to see what some of the pro's around here typically do with plastic bumpers and fenders.
I've seen a shop prep a bare plastic honda bumper with rubbing alcohol and spray adhesion promoter right before the application of basecoat/cc. Can't say for sure if this is the norm, but I know the guy that owns the car and 2 years later the paint is still adhering perfectly. - this was Sherwin Williams base. So you guys that work collision. Whatd'ya do??? |
the dplf is what i used to use..expensive stuff..and i used 402 once..by mistake..it all peels off as soon as you spray wash it!!.
I now use bulldog also..never had a problem.. bulldog, then base or bulldog and primer if needed, |
PPG one choice plastic prep system for raw plastic... #1 scrubber sponge #2 adhesion wipe #3 adhesion spray... that's how I do raw bumpers or mirrors and works great... then your epoxy or what have you... haven't used SPI adhesion spray... ?
I wash mine 1st with a water based wax and grease remover, then use "scuff it" paste with a grey scoth brite pad, wash again with water w&g remover, shoot with ad promoter, thin sealer coat epoxy, base and clear. I use the water based w&g remover from SPI along with the ad promoter from SPI.
you need to really tack the plastic good because there will be a lot of static build on the part. I haven't ever used ks epoxy, but I have used some of their other paints and they are decent quality very forgiving. Read the tech sheet and make sure its a suitable primer for plastic that stays flexible. After epoxy coat treat it as any other panel just remember that there will still always be more static build with plastics. |
| Steel Fenders | chief36chevy | Hotrodding Basics | 4 | 02-03-2011 10:26 AM |
| 36 Ford Steel fenders | Fassteddy | Introduce Yourself | 3 | 05-02-2007 11:37 PM |
| Honda Element-plastic composite fenders-simulate the paint | lexicon1 | Body - Exterior | 1 | 03-18-2006 09:53 AM |
| Plastic Steel or the equivalent... | Dragon J | General Rodding Tech | 23 | 03-15-2004 09:34 PM |
| 1936 Ford steel rear fenders | jamesgang2@alltel.net | Body - Exterior | 0 | 11-28-2002 07:25 PM |
