Painting plastic inner grill - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2005, 02:50 PM
New Member
What method do you all use when painting something like a plastic grill that is going to be exposed to weather and bugs.
Thanks
Old 10-05-2005, 08:32 PM
What kind of plastic? Is it an original grille and what is it out of?
Old 10-06-2005, 10:45 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
If it is part of a bumper assembly etc.. I use adhesion promoter like Bulldog, and paint it like I would the bumper.. bulldog... epoxy... base... clear
Note: Not all plastic requires adhesion promoter but I just use it on everything and dont worry about it.. It does not hurt to use it
Matthew
Old 10-07-2005, 05:36 AM
milo's Avatar
point on positive
I too have had excellent results with the Bulldog Promoter.
What I like best is it is available in a spray can and a little goes a long way.
a single coat seems to work better than the recomended 2 in this reporters opinion
Old 10-07-2005, 02:14 PM
Matthew
The grille he is painting is ABS so no need for promoter on this one.
Help painting ABS plastic. TurboS10 Body - Exterior 10 08-27-2012 09:30 PM
Painting in your Garage Centerline Body - Exterior 22 08-31-2007 10:23 AM
Plastic Grill pieces sscamaro_510 Body - Exterior 3 12-28-2004 09:00 PM
Painting plastic Lonestar Body - Exterior 2 09-07-2004 07:35 PM
Painting plastic trim on 96 S10 77chevy400 Interior 1 09-05-2003 04:59 AM
