Painting polyurethane - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2005, 05:00 PM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
Alright awhile back I wanted my whole truck to be blue and so I bought a reproduction dash from jcwhitney that was blue. This was a while back and since then I changed my mind and thought my truck would look a lot better black. Im not sure if paint would stick to the polyurethane or not, because when I was putting it in I had to glue the little metal dash clips to it and the gorrilla glue would not stick to it. Is there a paint you would reccommend for this?
Brad
Old 03-17-2005, 07:50 PM
mikev's Avatar
New Member
oil
An oil base paint should stick to the poly
Old 03-17-2005, 11:15 PM
Gone fishin'
Wiki Edits: 2
How durable is it? Because this truck is a daily driver, and I don't want it chipping and that kinda crap. Is there a brand you would recommend over another?
Brad
Old 03-19-2005, 04:37 PM
New Member
Plasti-coat paint is made for vinyl and plastic, any auto store should carry it.I used this product on door panels before and it worked ok.
Old 03-20-2005, 07:49 AM
Gone fishin'
Wiki Edits: 2
I thought about using that but I wasn't sure because the material on the dash is different than door panels, Ive had trouble with gorilla glue sticking to it when I was putting it in. Do you really think it will stick because the polyurethane has a kinda of a greasy slick type feel to it.
Brad
Old 03-20-2005, 11:08 PM
milo's Avatar
point on positive
I don't know why they call it dye cause it seems to act more like a paint. .anyway mabe the SEM company has what will look good as well as hold on...
http://www.autostyles.com/sem.htm
Old 03-21-2005, 02:45 PM
milo's Avatar
point on positive
OR ,,, another idea would be to use a bit of adhestion promoter and whatever else you wanted
http://www.levineautoparts.com/buladprom.html
hope to have helped
Old 03-21-2005, 07:19 PM
Gone fishin'
Wiki Edits: 2
Thanks bro, Im not so sure about that dye but it does sound like it should work. And I never even thought about an adhension promotor, it seems like its work a shot so I will give it a try. Thanks for all of yalls help I appreciate it.
Brad
Old 03-22-2005, 03:34 PM
Last journal entry: Latest picture
If you paint polyurethane or polyethylene, you will have problems down the road. Trust me! These plastics have built-in mold release and cannot be properly painted. That's why they are molded in color. Door panels can be painted because they are either made prom a vinyl or ABS product.Dan
BTW ! A quick way to tell if a plastic can be painted is to rub a bit of lacquer thinner on it. If it melts, it can be painted. If it doesn't, then you're stuck with the color it was molded in.
Old 07-10-2005, 08:44 AM
Gearhead forever's Avatar
Thats a cool tip......
Enamel vs Urethane vs Polyurethane???? MARTINSR Body - Exterior 11 07-02-2011 06:58 PM
Painting in your Garage Centerline Body - Exterior 22 08-31-2007 10:23 AM
Painting Interior trim bigjoedo Interior 7 01-08-2004 01:53 PM
Painting a computer case? Grump Body - Exterior 9 10-08-2003 08:26 PM
chassis painting 38 special Body - Exterior 3 03-10-2003 12:22 PM
