Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - painting questions
Old 02-20-2012, 03:00 PM
aarias-31 aarias-31 is offline
painting questions
Hey Hotrodders. I am attempting to paint a father son truck project. I am going to be using paintforcars auto paint. We are going to use the base/coat clear/coat paint. He is thinking about a medium blue metallic or a medium gray metallic. My question is should we use a epoxy primer/sealer in black so the paint will cover better? And can we use epoxy primer over some sanded but, not bare metal? Also, if we spray the epoxy primer/sealer do we have to paint within 24 hrs or less? Their website states best results and adhearing if sprayed within 24 hrs after epoxy primer/sealer?
Has anyoneever used this brand before? We are not wanting to spend to much on this because we have never sprayed this big of a project before, only small stuff like utility trailers and go cart frames, etc...
