Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Painting questions
Old 05-09-2012, 03:46 PM
swvalcon's Avatar
swvalcon swvalcon is offline
Last journal entry: rust on lt body shell
I would wait longer on your epoxy maybe at least and hour. THen put down your 2-k. I always let mine dry overnight and sand before I put down my 2-k but thats just the way I like to do it. All the 2-k seems to be different on dry time to sand but should either say on the can or ask your jobber you got the primer from. Your primer should be sanded with 320-400 untill perfectly smooth. Anything you can see in the primer you will see in the paint only more so.
