painting in sections - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2004, 09:59 AM
Toe Toe is offline
Smile painting in sections
Can you paint a vehicle in sections at a time, using a solid color?
Old 10-01-2004, 11:15 AM
Dragon J's Avatar
Last journal entry: Harley/Fire
If no graphics are involved and it is a solid color change from the previous, yes- I have done it many times. When painting a metallic or pearl it flows a little better it seems when it is together. Solid color shouldn't be a problem as long as the mix, shop conditions and pressure to the gun is the same!
Old 10-01-2004, 11:22 AM
poncho62's Avatar
Wiki Edits: 5
I painted my pickup separately with metalic paint. Matched up pretty well, but some purists would say it doesn't.
Found it easier to paint it this way.
Ontario Rodders
Old 10-01-2004, 02:05 PM
Im trying to have an idea!
Re: painting in sections
do you mean at diff tims, or at same it in diff sect
Old 10-02-2004, 09:46 PM
Toe Toe is offline
paint in sections
At different times. Same paint from the start.
Old 10-03-2004, 10:28 PM
Re: paint in sections
how far apart
Old 10-04-2004, 11:49 AM
Toe Toe is offline
paint in sections
Maybe a week apart.
Old 10-04-2004, 01:04 PM
As it was said it depends on the temp, humidity, air pressure, and paint mix of the different spray times, you would be better off to do it at least on the same day with the same paint mixture...
