Painting sequence to minimize overspray? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2009, 07:20 PM
bobyell's Avatar
I've painted my bird , cleared it a few days ago, it had some runs , and some orange peel, so I wet sanded it down with 400 grit. Sprayed two more coats of clear today. But I keep getting over-spray on the panels.
For instance, paint the hood all looks well, then paint the fender. Over-spray gets all over the hood? Is there some secret to minimize this?
Unfortunately I have to redo the hood tomorrow. i didn't notice the seal on the paint cup was out of place when starting the hood , dumped a pant load of clear all over the hood..
Bob
Old 10-31-2009, 09:13 PM
302 Z28's Avatar
Bummer, if your getting over spray on the hood after a coat of clear when spraying the fenders perhaps your spraying too dry. Generally it takes around 10 minutes or so for a coat of clear to kick to where over spray would lay on top of it. At any rate the clear over spray should not hurt anything, it will be the first thing to go once you start wet sanding.
Vince
Old 10-31-2009, 09:42 PM
bobyell's Avatar
OK got it. I may have dropped the supply pressure today and fluid. Ill bring it back up tomorrow. Hopefully it will go better tomorrow,
Thanks
Bob
Old 11-03-2009, 11:19 PM
Countilaw's Avatar
Cox Custom Cars
If you are painting in a paint booth, always start with the end closest to the exhaust fan. The over spray will melt into the wet clear.
Frank Cox
Cox Custom Cars
Old 11-04-2009, 09:12 AM
cyclopsblown34's Avatar
Colorsanding painter
Frank Cox
Cox Custom Cars
Thanks Frank, you just taught me something I never thought of.
Old 11-04-2009, 07:01 PM
Countilaw's Avatar
Cox Custom Cars
That's what hotrodding is all about. We learn something new everyday.
Frank Cox
Help! Newbie first paintjob, acrylic enamel issues KNanthrup Paint 65 06-08-2013 10:57 AM
Painting a Metallic in pieces Polish Painter Body - Exterior 18 09-11-2010 06:16 AM
Painting, getting cold... don't feel like blowing up dest1971 Body - Exterior 8 11-01-2009 04:53 AM
Painting a computer case? Grump Body - Exterior 9 10-08-2003 08:26 PM
