-   -   Painting a step side (http://www.hotrodders.com/forum/painting-step-side-223464.html)
chief36chevy 08-28-2012 05:34 PM
How do I paint up under the roll at the top of a step side pickup bed?
I have a gravity feed gun and a siphon feed gun, but I canít seem to get the right angle to hit up under the rolled edge.
I tried to turn the bedside upside down to apply epoxy primer but that didnít help I just got a lot of runs trying to get the correct angle.
Any thoughts?
Do I need a special gun or tip with a 90 degree angle?
:confused:
WriterDennis 08-28-2012 06:29 PM
Stepside bed painting
I would think that if you took the fenders off, you could probably paint the area you are speaking of. You may need to use a "detail" (aka jamb gun) to do it, but I think just removing the fenders will help you immensely.
Dennis W. Parks
author of automotive how-to books
monster76 08-28-2012 07:00 PM
i don't know if its the right way but it has worked for me if you can pull the fenders off assuming its bc/cc make your fan narrow and do several light coats up in there with a little more distance than usual and then widen the fan and continue painting as normal it has worked for me but then again i did only once and i guess it was more luck than skill
chief36chevy 08-28-2012 09:20 PM
I have the sides off the truck and the fenders are also off.
I will try the narrowing of the fan on the other side. Wish me luck.
monster76 08-28-2012 09:26 PM
post some pics of the results hope it works out for you.
monster76 09-13-2012 08:23 PM
how did it turn out? any pics of it
kobaltblue 09-22-2012 09:00 PM
I'm sure your done but....
Thats what I do narrow it down to almost a circle spray then widen the fan out a little make another run then widen the fan again and finish,That way it keeps a wet edge, Adjusting my paint flow as I go.
chief36chevy 09-25-2012 05:05 PM
I tried that on the other side with the epoxy primer, but I must have rushed the second coat as the Bondo showed through. I got a few runs where I tried to paint the inside of the pockets. Good thing I am working with the primer I can repair the primer. Iíll probably have plenty of coats of primer before the AE.
Iím hoping for better results with poly and AE.
:embarrass:rolleyes:
