Painting a step side - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2012, 05:34 PM
chief36chevy's Avatar
Last journal entry: New exhaust system cont.
How do I paint up under the roll at the top of a step side pickup bed?
I have a gravity feed gun and a siphon feed gun, but I canít seem to get the right angle to hit up under the rolled edge.
I tried to turn the bedside upside down to apply epoxy primer but that didnít help I just got a lot of runs trying to get the correct angle.
Any thoughts?
Do I need a special gun or tip with a 90 degree angle?
Old 08-28-2012, 06:29 PM
Dennis W. Parks
Stepside bed painting
I would think that if you took the fenders off, you could probably paint the area you are speaking of. You may need to use a "detail" (aka jamb gun) to do it, but I think just removing the fenders will help you immensely.
Dennis W. Parks
author of automotive how-to books
The Following User Says Thank You to WriterDennis For This Useful Post:
chief36chevy (08-28-2012)
Old 08-28-2012, 07:00 PM
i don't know if its the right way but it has worked for me if you can pull the fenders off assuming its bc/cc make your fan narrow and do several light coats up in there with a little more distance than usual and then widen the fan and continue painting as normal it has worked for me but then again i did only once and i guess it was more luck than skill
The Following User Says Thank You to monster76 For This Useful Post:
Old 08-28-2012, 09:20 PM
I have the sides off the truck and the fenders are also off.
I will try the narrowing of the fan on the other side. Wish me luck.
Old 08-28-2012, 09:26 PM
post some pics of the results hope it works out for you.
chief36chevy (08-29-2012)
Old 09-13-2012, 08:23 PM
how did it turn out? any pics of it
Old 09-22-2012, 09:00 PM
kobaltblue's Avatar
I'm sure your done but....
Thats what I do narrow it down to almost a circle spray then widen the fan out a little make another run then widen the fan again and finish,That way it keeps a wet edge, Adjusting my paint flow as I go.
Old 09-25-2012, 05:05 PM
I tried that on the other side with the epoxy primer, but I must have rushed the second coat as the Bondo showed through. I got a few runs where I tried to paint the inside of the pockets. Good thing I am working with the primer I can repair the primer. Iíll probably have plenty of coats of primer before the AE.
Iím hoping for better results with poly and AE.
1955 step side leroy.archibeque Engine 1 07-26-2007 08:36 AM
1970 GMC step side poy41 Body - Exterior 0 09-23-2006 12:56 AM
*Help* 72 Chevy P/U with Step Side Box *Help* Mustangsaly General Rodding Tech 8 01-20-2006 09:07 PM
1953 step side back kfowler Body - Exterior 2 10-26-2003 12:37 PM
89 chevy 1/2 ton step side johnsongrass1 Engine 0 09-09-2002 12:31 PM
