Painting stripes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2005, 09:09 PM
Painting stripes
Hey
When I respray my car I'm spraying 'stripes' down the side but I don't know when to spray them. Should I spray my base and then spray the white stripes or should I finish and spray my clear then spray the stripes etc. any help appreciated!
Thanks
Troy
Old 03-31-2005, 09:24 PM
This is dealers choice. You could spray the white first,mask them then base. The ways you mentioned will work to. There is no wrong way really.
Old 03-31-2005, 10:05 PM
outlaw17's Avatar
If both colors are base , it would be easiest to do both colors then clear over both . Which order to paintyour 2 colors depends on the design , it would probably be easiest to do the stripe first . Just be carefull when you clear because you will give yourself an edge for the clear to hang off of.
Old 03-31-2005, 11:12 PM
milo's Avatar
point on positive
In almost all cases rule of thumb,spray the color you'll see the least of first.
http://www.a2zautoforums.com/showthr...railer+Stripes
1971 Chevelle SS Stripes For A Clone. M&M CUSTOM Body - Exterior 8 09-23-2004 06:08 AM
Painting Stripes jerrylo Body - Exterior 1 09-03-2004 11:55 AM
Painting a computer case? Grump Body - Exterior 9 10-08-2003 08:26 PM
Painting stripes 77Cobra Body - Exterior 3 04-26-2003 04:08 AM
