Painting temperature? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2011, 12:09 AM
I have my car primed and ready for paint, and plan to paint it tomorrow. My question is the daytime high should be around 70 degrees but the low's at night will dip into the mid 40's. If i paint it during the day will the low nighttime temps affect the paint? Also the paint is John Deere Blitz Black. Thanks.
Old 06-03-2011, 07:20 AM
delawarebill's Avatar
paint'n
shouldn't have a problem. but ck the label for the activator and see what temps it recommends... or ask the dealer for that info....
Old 06-03-2011, 08:01 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Your friend is one of those infrared thermometers..i want the metal to be 60 degrees plus before I paint so roll it out in the sun before you shoot it..
Sam
Old 06-03-2011, 10:03 AM
67Elcamino's Avatar
John Deer Blitz black
PLase let us know how it goes with the John Deer Blitz black. I was planning on using it once but opted to use PCL Flat Black instead.
Is John Deer paint have an activator or is it ready to shoot. I would like to try it one day but not sure If I can get it here in California
Old 06-03-2011, 02:05 PM
The dew point should be at least 5 degrees below the temperature. Otherwise, there WILL be water on the substrate's surface.
The Following User Says Thank You to Cruzin90 For This Useful Post:
RLDSL (04-04-2013)
Old 06-04-2011, 12:20 PM
It turned out pretty good, i mixed 8 parts paint, 1 part thinner and 1 part hardener, Thanks for all the responses
ID:	55797   Click image for larger version
Old 03-27-2013, 10:34 AM
33Willys77's Avatar
deleted - responding to another thread and came up on this one. ??
Old 04-04-2013, 02:06 AM
Now THATS the kind of precise information I've always been looking for. Temps are always running crazy around here and I've wound up shooting in darn near freezing ( not by choice, snuck up on me )and it's come out great.... but its the moisture in the air that has more to do with it than the temp, Ive had other times teh temp has been in the supposed perfect range, but the stinking humidity threw a royal wrench in things. I'm pretty much limited to spring and fall I finally figured out until I get rich and can afford some contained shooting space with some climate control.
Temperature range for painting Blitz Black? Daddoo X Body - Exterior 8 10-23-2010 03:13 AM
temperature zoomo Engine 8 09-19-2010 07:29 PM
Ac Temperature 40forddgc Hotrodding Basics 5 08-17-2010 01:40 PM
Max PCM temperature 49Austin Electrical 1 04-16-2010 05:56 PM
454 operating temperature ratlover Engine 4 04-25-2004 08:29 PM
