Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - painting with torpedo heaters question
Old 12-21-2004, 12:05 PM
mrcleanr6's Avatar
mrcleanr6 mrcleanr6 is offline
if you pile the clear on and then heat it up in there to bake it, you might have a problem with pop but you want to heat the garage up first to make all the parts warm. if you dont have great ventilation i would then turn the heater off, spray then turn it back on to warm things up. just warm up...thats all. let the clear set for a few hours to be safe then turn the heat back on to bake them if thats what you are going to do. just allow the clear plenty of time to flash, dont pile it on then bake it right away and you wont have a problem with solvent pop.
