Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Painting a truck - Pretty handy guy, but need a jumpstart
Old 01-02-2013, 07:33 AM
Will312 Will312 is offline
Thanks for the advice. If you wouldn't mind going into a little detail as far as the benefits of Epoxy primer over the other choices, it would be greatly appreciated. You seem to have a lot of knowledge on the area and I wouldn't mind picking your brain a bit.
The general technique, i've played with and got good results - really the paint type is the big thing for me. Each paint has a tech sheet that tells you what to do. I can follow directions pretty well.
Really, just the types of paint and what the best application for them is would be wonderfully beneficial.
Of course - if you want to give me a run down of the whole thing, I will most certainly read it.
