Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Painting in your Garage
Old 11-04-2003, 08:05 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
I used 4' florescent shop lights. I put 3 along the walls on each side and I built a ceiling with slanted ceiling and put 6 more up there. I built boxes of 2x4s lined with drywall and painted white to house each light. Then I made a 1x2 wood frame that I covered in 20mil clear plastic sheet that is screwed over the light holes that seals them from the fumes but is easy to change if they get dirty. These lights are cool and give off white light so you can see what is going on.
I have a question for you Centerline - how in the smell did you get your garage so clean? Where is all the "stuff"!?!
