Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
Good grief, but these oldies do reappear. My one and only post on this thread was in Aug 2006
Now days you have to be inventive and come up with your own methods of cleaning engine blocks. An old engine machinist years ago said, Quote:
Ever notice that today, "rebuilt" engines in a Mom & Pop type car just don't last like a factory engine? The factory can use a CNC machine and get to tolerances that we at home have to use a "Cylinder Hone" to get proper piston to wall clearances. Next engine you build, after it's been cleaned, take some brake cleaner and spray the cylinder walls and see if some grey dust don't come out! Not gonna point fingers here as a N00b I'd better not, however much "general" knowledge can be gained by reading, here's 3 that I've read in the past and found some good info; Smokey Yunick's "Power Secrets" HP books How To Hotrod [insert your Make] Book Engine Blueprinting |
Well I ran the block hone and wash line at Int'l Diesel Huntsville. These went thru a wash cycle of about 30 minutes in a hot wash that the water was filtered thru 5 micron filters....big, big ones changed every 4 hours. When the dry block came out it you could take a white tissue to the bores and safely wipe your behind with it. The blocks were then conveyed thru a covered enclosure until the assembly began. No dirt anywhere. The guys on the assembly line didn't even get dirty working.
The cranks, heads and all other internal parts had similar wash and dry cycles somewhere in their assembly. We had unlimited supplies of various gloves and gauntlets to use. Even the overall plant was cleaner than most homes. Not many people got sick there either. How clean is your clean room?? I use more soap and hot water cleaning motor, trans, and rear end parts than I do for washing clothes. haha Painting the inside of the motor ranks up there with "if it don't go chrome it..." Show me the data where more hp was made with "gut" painted motors. |
I'm surprised no one has talked about the 25hp gain from painting the right half of the block internals red and the left half blue, it increases cooling by a bajillion percent and triples the viscoflowhesion properties of the oil. I also strengthens the iron by 15% but that's a minor benefit...
Ok, so exactly what is it that you think it does for oil? Besides creating a thermal barrier. |
Although there are few benefits to using glyptol paint anywhere inside an engine and few if any negatives if applied properly there is one big benefit if you race and tear an engine down often.
Its a lot easier to clean and keep clean while disassembled, probably why Smokey used it...he was a practical guy. If you ever tried to wipe off a smudge of grunge off a bare casting with a shop towel before you know its impossible to do it without tearing fibers off the rag...try and get that stuff off! Bare cast iron is like velcro to a rag. If a layer of paint is causing cooling issues you have bigger problems than a layer of paint to deal with, it has its place like most old wives tales that get distorted as though they are magic in some way. Kinda like the battery on concrete wives tale...not really dumb when you consider at one time batteries weighed a hundred pounds and had glass cases. Try and put that down carefully while greasy on concrete without dropping it or cracking it.
Outlawed tunes from outlawed pipes |
Not much to add here; other than New Process Gear used to paint the inside of their transfercase halves with Glyptal. I don't think a huge company like NPG would invest in that on a production schedule unless there was some benefit somewhere.
thinkig it will get the oil from the heads down to the cam faster, needing all the help i can get to keep the cam oiled |
Couldn't the same basic benefit be gained by simply enlarging the oil drainback holes?
My concern would be that unless the paint has the exact same coefficient of thermal expansion as the metal the block is made of, eventually, no matter how clean it was and how carefully the paint was applied, it will at some point in the future begin to crack and flake off into your engine... I guess for me I don't see the potential benefits outweighing the potential negatives on this one.... Last edited by MJS69; 12-23-2011 at 10:51 AM. |
| Recent General Rodding Tech posts with photos |
| Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| ENGINE BALANCING | NAIRB | Engine | 14 | 09-06-2011 08:22 PM |
| 1973 Chevelle Malibu Engine Rebuild (pics 56k no) | Malibu73 | Hotrodders' Lounge | 39 | 11-04-2008 12:37 PM |
| setting points on sb chevy | frackster66 | Electrical | 14 | 03-22-2008 11:33 AM |
| question for any engine builders out there | mopar72 | Engine | 7 | 11-06-2005 03:06 PM |
