Pan gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2002, 02:40 AM
Post Pan gasket
Is there any advantage to using one of those new one piece pan gaskets over the standard 4 - piece on a Chev. 350????? Has anyone used the one piece?? Any problems?? <img src="confused.gif" border="0">
Old 10-10-2002, 04:33 AM
Post
Wow all i know is that i had a lot of trouble with my timing cover leaking where it ment the pan. But that was with a 4 piece i dont think it could of been any harder.
Old 10-10-2002, 04:53 AM
SAE Member; ASE Master Cert
Post
The one piece pan gaskets work real well. I would recommend them in all cases. Do not use any sealer with them, just make sure all sealing surfaces are clean and dry.
