Pan level VS stick level th350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2010, 01:36 PM
A fortunately unfortunate thing happened today. Got the transgo th350 1and2 kit. Put it in,ofcourse after realizing it really is no different than the B&M stuff and once again a perf comp lied to move a product. Anyhoo all that aside I pinched the pan gasket and it spewed tranny fluid. My question is how much of a difference is there tween running tranny level and stopped engine tranny level? Cause my chinese dipstick says I need a quart and change, but as the cars up on the hoist shut off its spewing a good quart out this pinched spot in gasket, which would have me believe near a 6 quart diff tween running and sut off REALLY?
Old 07-03-2010, 11:25 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
a 6 quart drain back at engine shut off? Never seen that. Not quickly either
I have seen some dip stick - tube assemblys off quite a bit
Old 07-03-2010, 02:19 PM
Wonder how a fella could tell when he's got the right level? At shut off I shouldnt have more than a pan full should I?Wonder how close I'd be if it were on the hoist and I loosened the pan just enough that it started leaking out the front ,then retightened when it stopped
Old 07-03-2010, 04:46 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
This is from the Chevelle Tech forum and adequately describes what I do.
http://www.chevelles.com/forums/showthread.php?t=68139
Old 07-03-2010, 05:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
FWIW, Art Carr says the ATF should be 1/4" above the pan (pan overfilled by 1/4", in other words) w/the engine off, tranny cold.
Old 07-03-2010, 05:50 PM
Thats what I got now. So even though my stick says add a quart I'll leave it
turbo 400 with deep pan orangecrush Transmission - Rearend 8 12-15-2005 04:46 PM
TH350 leaking pan dawg Transmission - Rearend 16 02-08-2005 02:38 PM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 09:58 PM
Oil Pan/ Windage Screen Problems DTL504 Engine 4 05-13-2004 05:37 PM
2nd Hand TH350 pan contents Neil_UK Transmission - Rearend 5 07-07-2002 07:27 PM
