panel adhesive - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-14-2006, 11:54 PM
Originally Posted by mrcleanr6
what i have done in the past was epoxy prime the lip of the wheel well where it meets the inside of the quarter then also epoxy prime the quarter in the same area. i then use 3m urethane window adhesive, load up the quarter. push it together until it oozez out, scrape off the excess and your sealed and bonded.
Jim, for years I installed doorskins this way, using urethane window adhesive and also urethane sealer/adhesive with the only welding done on the ends near the hinges and latch areas. The urethane bonds and seals really well and does stay flexible. I agree, there's many ways to skin a cat. Bob
  #17 (permalink)
Old 01-15-2006, 02:50 PM
adtkart@aol.com
I sure hope you guys keep those vehicles close to home. Our customers are very well trained. They can repeatedly tear up a vehicle the same way, time and again. We have had them re-wreck them the same day they get them back. I hate the thought of having to cut thru that for a future repair.
  #18 (permalink)
Old 01-16-2006, 12:50 PM
Another Bonding/Welding Question
If the panel is bonded only, is there an offset flange on one of the panels, new or old, used as an area for the bonding agent to go on? Do you make a flange with a tool or does the new panel already have a flange? If welding destroys the bonding agent, does that mean you leave a space between the bonded area and the welded area so there is no problem with the heat from welding? What do you do with this "area"? filler or ???. Thanks .
  #19 (permalink)
Old 01-16-2006, 05:22 PM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
The areas where structural adhesive is commonly used are inside flanges that would normally be welded and called "pinch welds", and inside the hammered over flange of door skins. There is no visible gap in these cases, and any discontinuity in sealing would be handled by seam sealer just before paint.
  #20 (permalink)
Old 01-18-2006, 01:20 PM
boatbob2
hi guys,about panel adhesive,most of them are ok,but take 2 pieces of metal with the adhesive and try to pull them apart in shear,and you will find they are no good. the only good one i have ever found is 3 M 5200...home depot sells it. it will work with painted or bare metal.best is if you can clamp it. it takes 2 or 3 days to really set up...but I guarantee you will never pull the repair apart. its waterproof too. its a kind of caulk...but ive been in the fiberglass boat repair business for over 30 years and ive never had a problem with it.you clean the excess off with acetone.
  #21 (permalink)
Old 01-18-2006, 02:46 PM
Magnus_Jager's Avatar
Tow Chainer
Last wiki edit: Rebuilding an early Hemi engine
Last journal entry: cruise pics
Wiki Edits: 2
As for welding around it, it strinks to high heaven when it burns. I suggest not doing it. Probably not healthy either.
  #22 (permalink)
Old 01-18-2006, 03:09 PM
You can do partial panel replacment, patch panel work with adhesives, go to Lord Fusor's website for some excellent info/instructions on these proceedures.----------
http://www.lordfulfillment.com/upload/RP3006.pdf
http://www.lordfulfillment.com/upload/RP3005.pdf
http://www.lord.com/Default.aspx?tabid=1149&pid=5
  #23 (permalink)
Old 01-18-2006, 07:26 PM
mrcleanr6's Avatar
i have spent alot of years working in the marine industry too and 5200 is great stuff. its the same thing as the window adhesive i mentioned above. basically urethane caulking.
Help! What To Do With These GIGANTIC Dents!? mistermuscles Body - Exterior 14 09-16-2005 06:24 AM
Metalshaping/Body Panel Fabrication Randy Ferguson Body - Exterior 15 06-07-2005 12:01 AM
wanted: an answer to a simple question ikeaguirre14 Body - Exterior 4 05-15-2005 08:23 PM
Repair of large dents in roof? rlackey Body - Exterior 9 01-28-2005 11:36 PM
Quarter Panel Patch Ron M Body - Exterior 1 07-27-2004 02:12 AM
