Panel adhesive questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2009, 06:32 PM
Having never used this space age miracle I have a couple of questions for you guys.
Will it adhere to the pot metal/aluminum that a early GM sport mirror is made of?
Will it bond to plastic?
Will it bond the aformentioned metal to the plastic?
I am not concerned about seeing the bond joint, it will be hidden inside the mirror housing.
What is the best material to use?
Thanks!
Old 04-17-2009, 08:02 PM
302 Z28's Avatar
I don't know of which you speak, but some of the toughest adhesive around is urethane windshield adhesive. It'll pretty much stick anything to anything.
Vince
Old 04-18-2009, 05:15 AM
Vince
Either do I! lol.
I know there are a number of different structural adhesives on the market, but have no knowledge about them.
Old 04-18-2009, 06:22 AM
Lord Fusor makes adhesive that wil bond
Metal
Fusor Metal Bonding Adhesive
Does bond aluminum and steel can bond he two together. 50ml cartridge #111B $16.49
PLastic
Fusor Plastic Bonding Adhesives
High strength structural adhesive
Bonds SMC, Fiberglass, carbon fiber and other plastics to itself, primed metal and more 50ml cartridge #140 $16.49
Plastic to metal
Plastic to metal cross bonding adhesive
Bonding bare metal to fiber glass, FRP, SMC, carbon fiber, ABS, and poly carboate acryilic
300 ml cartridge #!!6 $39.49
This is just a few of many adhesives avalible from this company. If you go to www.autobodytoolmart.com you can find the information on the adhesives and some from
SEM, Duramix, and #M AUtomix.
If you have any more questions let me know.
Fusor 108B panel adhesive question ScotY Body - Exterior 0 10-22-2008 12:52 AM
the door panel Question to end all door panel Questions Hogwild Interior 1 02-05-2008 01:24 PM
Metalshaping/Body Panel Fabrication Randy Ferguson Body - Exterior 15 06-06-2005 11:01 PM
wanted: an answer to a simple question ikeaguirre14 Body - Exterior 4 05-15-2005 07:23 PM
