Panel truck roof seam - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2010, 06:50 AM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
Hey all,
Happy Labor Day..I'm actually off this year I was just toying with the idea of filling the roof-to-body seam. I haven't seen this seem filled on many, (one to be exact), panel trucks. I assume mostly because of work involved. I am mostly thinking of it from an aesthetic point, but also what is the best way to seal it up in case the paint gets cracked, scratched, etc. I stripped it all down to bare metal and it was covered with epoxy...but does that really seal such a crevice? The attached pic shows the seam where it meets the door opening....
Name:	march 26 003.JPG
Old 09-06-2010, 11:48 AM
phipp13's Avatar
panel truck roof seam.
i recently re-skinned my 1972 C-10 roof. i used 3m 8115 Automix Panel Bonding Adhesive. it was expensive but that stuff was worth every penny! i have a similar seam across the rear of the cab roof . the 3m adhesive filled it up and stayed in the groove without gravity run out.it is waterproof also. good luck R, Phipp
Old 09-06-2010, 11:59 AM
Hwyhogg's Avatar
Well, I wasn't gonna re-skin it, I was just thinking about filling in place....sorry if I'm misunderstanding...thanks for the reply.
Old 09-06-2010, 01:03 PM
Niko1080's Avatar
Use short strand fiberglass filler, and hope it doesn't crack.
Old 09-06-2010, 10:48 PM
"i used 3m 8115 Automix Panel Bonding Adhesive. it was expensive but that stuff was worth every penny!"
short of welding the seam, this IS the best choice. Just be sure to get the seam as clean & dry as possible before you apply 8115 and leave it set-up over night. Fiberglass filler WILL crack out, not maybe.
Good luck with it.
1951 chevy panel truck lblsk Introduce Yourself 7 09-19-2011 05:45 PM
new guy from N.C. Got panel truck gas tank birdman1 Hot Rod Art 16 09-25-2007 08:22 PM
Panel truck? big willy Introduce Yourself 2 01-02-2006 07:03 PM
51 Ford Panel Truck BAD TO THE BONE 413 Introduce Yourself 4 01-02-2006 06:38 PM
Engine Suggestions for 38 Dodge Panel Truck sifua Hotrodders' Lounge 4 07-31-2004 04:31 PM
