Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Panhard bar interference
Old 07-09-2013, 05:46 PM
sedanbob's Avatar
sedanbob sedanbob is offline
Before you cut your panhard bar, try swinging a piece of tubing/wood/whatever cut to the shorter length along the arc that your suspension travel would allow and see how much side-to-side movement you'd get. You can minimize the side-to-side by making sure the panhard bar is level in the middle of the suspension travel at ride height. Make sure if you move the panhard mount on the frame, that it doesn't interfere with your suspension (lowering where it mounts on the differential would likely dictate lowering it at the frame).
