Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Panhard bar interference
Old 07-10-2013, 12:48 PM
327NUT's Avatar
327NUT 327NUT is offline
No it mounts on the pinion support, if you pull up totalcostinvolved.com and go to '32 Ford chassis you'll that this is the correct location. Also 27, make sure the panard bar is parallel to the ground at ride height so it can work properly. I really don't know how....if 27 did, hook up the panard bar to the top of the 3rd member housing. The mounting loc tab welded to the chassis is installed directly across (inline) with the pinion support, unless he used some kind of spacer (s) or ????. I think the second hole is for an 8" rear. Here's another picture.....
The Following User Says Thank You to 327NUT For This Useful Post:
27Tall T (07-10-2013)
